Busa_Havens
Need some help diagnosing an issue:
Background: ’08 Hayabusa with basic bolt-on modifications used exclusively as a drag bike (stock motor, pump gas, etc). Bike tipped over in the pits, cosmetic damage only. Start up the bike to double-check, warm it up, no issues so I prepare to make a ¼ mile pass. Pass feels solid, quick and the bike is moving. Shift into 5th gear and I feel as if there is a loss of power (not all power, just not pulling as hard as it should be). About the time I think this is a weird situation, there is a fast paced clanking coming from the motor. At this point I grab the clutch, kill the motor and coast off onto the return road. I remove my helmet and examine the bike for a moment and cannot spot any visible issues. I restart the bike in neutral and the clanking once again occurs at idle, so I shut off the motor.
At this point I have drained the oil (didn’t see anything unusual in the 3.5 quarts that came out), pulled the oil pan (didn’t see anything) and have removed the clutch basket (again nothing out of the ordinary that I can see).
Anyone have some advice on what to check?
