If you can't find help contact Traxxion Dynamics Shock Help. They will fax you a PDF on how to. Just don't tell them you bought another set of internals or do its up to you. I have the PDF file that came with my Axxion kit but it is all mucked up from fork fluid. I just did the install on my shocks. Its more to it than me typing about it, especially if you are doing with fresh fluid and so forth, which you should. I hope you have all the right tools.I would like to open up the cartridge to install the Race Tech Gold Valve but I can't figure out how to get the cartridge open to get to the valving on my 2004. Any help out there?
Thanks in advance!
If you take some pics I can help you out. Tough to give you good advice without seeing it. Can you snap a couple of shots.I have the cartridge (#7 in the figure) out, which was held in by the allen screw from the bottom. Once I got the cartridge (#7) out, I thought that I would unscrew the bottom of that and that is where the valving would be but I can't unscrew the bottom of #7.
Thanks and I appreciate your efforts in trying to help me! : )
Heat it up much easier, less damage...I talked with tech support at race tech and the guy said that they way I have been trying to open it up is correct but there is locktight that has to be broken loose so I have to wack it some before it will come undone. I will try that and let you know how it goes.
No problem I think I went with Maxima 7 weight Synthetic Racing Fork Oil. Glad you got it all worked out. If you really want to tweek that suspsension get your hands on a suspension for mortals seminar CD. Excellent info.Actually, the tech support guy said specifically not to use heat for this particular situation.
I did do as he recommended and hit the cartridge on the side near the bottom and it came off like it wasn't even tight! I will hit my good cartridge a bit more softly though, hopefully with the same results. So, I have taken care of my original post by hitting the side of the cartridge. I pulled apart the vavle stack like the video states and everything seems pretty straight forward. There is light at the end of the tunnel yet. I was able to find some Silkolene Fork Oil that actually had Spec 01 on the bottle...the actual weight of the oil...2.5W! I'm going to try it out since I have some pretty stiff springs in there.
Thanks again for helping me out GPW.
