bubba_zenetti
do you really have to ditch the oil cooler to fit a turbo? the information i have gathered suggests that it is no longer used. any problems associated with this or is this the norm for all street turbo setups?
+1. Make SURE you remove the screw from behind the oil filter.most turbos bikes do not use the oil cooler, the stock one must go, if you want a cooler i have one that will fit a turbo, i decided not to run one on mine. if you decide not to run one on yours take the filter off and take the block screw out of the top so more oil will flow into the filter
LIKE THIS ONEIf your running a drag bike or on the street for relatvely short runs the oil cooler is pretty useless, but if you ride a lot or in traffic keep the cooler, most turbo shops can supply kits to keep the stock cooler but there are some aftermarket pieces that look good
that is pretty nice. where does one get one of those?LIKE THIS ONEIf your running a drag bike or on the street for relatvely short runs the oil cooler is pretty useless, but if you ride a lot or in traffic keep the cooler, most turbo shops can supply kits to keep the stock cooler but there are some aftermarket pieces that look good
how does an oil cooler help you in traffic? you need air passing thru the cooler to actually cool it. thats why you have a radiator fan. if i am sitting in stop and go traffic in 90 degree weather what purpose is the oil cooler serving?If your running a drag bike or on the street for relatvely short runs the oil cooler is pretty useless, but if you ride a lot or in traffic keep the cooler, most turbo shops can supply kits to keep the stock cooler but there are some aftermarket pieces that look good
it still allows for heat to dissipate to the air. of course it is more effective if you have airfflow past the cooler to begin with. even your radistor is transfering heat to the air without the help of the fan or air flow.how does an oil cooler help you in traffic? you need air passing thru the cooler to actually cool it. thats why you have a radiator fan. if i am sitting in stop and go traffic in 90 degree weather what purpose is the oil cooler serving?If your running a drag bike or on the street for relatvely short runs the oil cooler is pretty useless, but if you ride a lot or in traffic keep the cooler, most turbo shops can supply kits to keep the stock cooler but there are some aftermarket pieces that look good
disconnect your radiator fan and go sit in traffic for awhile. do you think the heat is going to dissapate into the air and keep you from overheating? your stock oil cooler is a fraction of the size of your radiator so less effective. but you are going to put an aftermarket cooler on thats even smaller than that. i dont see much of a benefit to that when it comes to sitting in traffic. the harley guys i ride with have the big aftermarket oil coolers and oil temperature gauges. i see there oil temps skyrocket while sitting in stop and go traffic all summer long. now when you are cruising at a decent clip and you have a cooler the oil temp will be lower than if you have no cooler. in traffic are you just routing some of your oil away from internal motor parts that could use that extra volume? maybe someone can answer that i am interested in knowingit still allows for heat to dissipate to the air. of course it is more effective if you have airfflow past the cooler to begin with. even your radistor is transfering heat to the air without the help of the fan or air flow.how does an oil cooler help you in traffic? you need air passing thru the cooler to actually cool it. thats why you have a radiator fan. if i am sitting in stop and go traffic in 90 degree weather what purpose is the oil cooler serving?If your running a drag bike or on the street for relatvely short runs the oil cooler is pretty useless, but if you ride a lot or in traffic keep the cooler, most turbo shops can supply kits to keep the stock cooler but there are some aftermarket pieces that look good
Brian your right to a degree,{no pun intendeddisconnect your radiator fan and go sit in traffic for awhile. do you think the heat is going to dissapate into the air and keep you from overheating? your stock oil cooler is a fraction of the size of your radiator so less effective. but you are going to put an aftermarket cooler on thats even smaller than that. i dont see much of a benefit to that when it comes to sitting in traffic. the harley guys i ride with have the big aftermarket oil coolers and oil temperature gauges. i see there oil temps skyrocket while sitting in stop and go traffic all summer long. now when you are cruising at a decent clip and you have a cooler the oil temp will be lower than if you have no cooler. in traffic are you just routing some of your oil away from internal motor parts that could use that extra volume? maybe someone can answer that i am interested in knowingit still allows for heat to dissipate to the air. of course it is more effective if you have airfflow past the cooler to begin with. even your radistor is transfering heat to the air without the help of the fan or air flow.how does an oil cooler help you in traffic? you need air passing thru the cooler to actually cool it. thats why you have a radiator fan. if i am sitting in stop and go traffic in 90 degree weather what purpose is the oil cooler serving?If your running a drag bike or on the street for relatvely short runs the oil cooler is pretty useless, but if you ride a lot or in traffic keep the cooler, most turbo shops can supply kits to keep the stock cooler but there are some aftermarket pieces that look good
exactly. the added mass of the radiator and additional liquid spreads heat over a larger area. heat on any solid matter will transfer to air regardless of air flow.Remove the radiator from your bike and you will understand how much heat it dissipates even with no air flow. The same goes for the oil cooler but on a smaller scale.
