good machine shop for crankshaft work?
Nicholas
i need my crankshaft journals polished and cleaned up does anyone suggest a company other than ape? they are kind of pricey but at the same time i would like good work done before i send it out
well, on my billet cranks I've had him do lots of things such as inspection and detailing. I've had him inspect and micro-polish journals, Check cranks for twist, grind base circle of counter weights, plasma-nitride coat, smooth the leading and trailing edge of the counter weights, dynamic balance the crank, and a few other things as well.
On an OE crank you might be better off just buying a new crank. If it's a Gen1 crank you, can get them very cheap brand new. Would probably end up costing around the same.
where a good place to look for new crank? its not really damaged much but it had a nic on one of the side of journals and do u know if or where anyone sales lightened and balanced cranks?
unless you race there's no benefit to the costs for a lightened crank. There not common enough to be considered an "off the shelf" item so you would have to have your crank machined and balanced if that's what you want. I know Orient express was selling new Gen1 cranks at a good price but I'm sure there are other vendors as well.
holy ish...without seeing my crank they start at 300 for repair.... hmmmmm... wtf.... hunt for a new crank
WE have new race balanced Gen 2 cranks with spacer to stroke your gen 1 motor.
We keep these in stock.
Haybausazone - Crankshafts
I was surprised by the "pricey" comment. For lightened and balanced cranks, we are almost 1/2 the price of the competition.
