Italian Trev
I used to pull away in 3rd .....:
I think we might have found the problem
Watched a guy at the drags on a Honda CBR1000 fry his clutch doing burnouts. He gave it full throttle and let the clutch out but not enough to spin the rear wheel. He kept doing it over and over trying to spin the rear wheel. Everybody was yelling at him to leave the clutch all the way out but he couldnt hear.By the time he got to the starting line his clutch was fried and he went through the quarter at about 10 MPH.
You know what? After reading your post, I think I might have done it myself. That was my first time trying to do a burnout and I don't think I let the clutch out enough. I didn't max the throttle but I did try a few times to get my back tire to spin. I got it to spin once after I realized I wasn't letting out the clutch enough. That is probably why after I took off, the bike started feeling different, like I lost a lot of torque when I hit the throttle. Thanks for your input!!![]()
Sorry to bust your balls but I bold and underlined the problem.Ok, I got my K8 in mid June, I just went over 1700 miles with her today. I broke her in properly, never going over 5k rpms. Got my first service check done and she was riding like a champ, amazing torque in the low gears.
I have been doing a lot of riding the past few weeks and occasionally I will turn her loose for a couple hundred yards or so if the streets are clear. I have done nothing reckless with her with the exception of practicing a burnout a couple times.
Bingo! To do a proper burnout there is almost no slipping at all. It's pretty much a controlled dump. Just hold the brake hard, stand up to get your weight off the chassis, then bring your revs up, and release the clutch quickly maybe one second from on to full off. This will keep the shock on parts low but enough to break the tire loose with ease.You know what? After reading your post, I think I might have done it myself. That was my first time trying to do a burnout and I don't think I let the clutch out enough. I didn't max the throttle but I did try a few times to get my back tire to spin. I got it to spin once after I realized I wasn't letting out the clutch enough. That is probably why after I took off, the bike started feeling different, like I lost a lot of torque when I hit the throttle. Thanks for your input!!![]()
What's a TRE?![]()
Well, not saying this isn't the culprit...... that whould have to have been one hell of a burn-out trial ??? LIKE i said earlier"if your telling the truth", im not calling you a liar, but just maybe you whernt doing some right(for a LONG time) and didn't realise it, like bogas said, cluthes will take alot of abuse before slipping that bad.
Timing Retard Eliminator Basically, retards your Rev limitor, making it appear to not be there because the bike thinks its always in 5th gear.
If you have basic tools you could replace the clutch yourself cause like guys said previously, sounds like you burned it up. Of course you could always see if the dealership will fix it for you first. 1700 miles is not a long time to wear out a clutch though... good luck with it and let us know what the dealership says.
I will do that, thanks. You a fellow Air Force brother I see, TSgt as well?
