Yes! This should not be here. Hello, quick shifter!Have they changed the shifter from Gen 2??
Wonder if it would make the fancy electronics act weird when you hit to up shift, but it downshifts?This is the gsxr1000R with factory quick shifter.
Technically you should be able to flip the arm on the upper shaft 180° to accomplish GP shifting.
I also have the factory service manual, but it makes no mention of GP shifting being an option.
The gen3 QS design is basically the same, so again, technically possible.
I have not tested it, but if the shift shaft height is adjusted within spec, it should work, as there is room for the shift shaft to move toward the rear, to connect to a flipped upper arm.
Takes about 5 mins, had to remove the Sprocket cover and turn the Linkage upside down. QS and Autoblip work perfectly
Can you take a pic, I tried to flip mine and the linkage is to close to workTakes about 5 mins, had to remove the Sprocket cover and turn the Linkage upside down. QS and Autoblip work perfectly
I tried both, either way my linkage lever doesn't allow it to mount on the shaftDid you try to flip the knuckle on the shaft or did you rotate it? I have mine GP as well and works fine once you get the lever height dialed in. Post a picture we can help
So I successfully flipped it, however when riding with the quickshifter it's acting funky and sometimes won't shift and will blink flashing a QS on the dash... If the shifter has an auto blip for the down shifts, I'm wondering if I have to actually flip the QS around so it's actually going in the correct direction
Yes we are talking about a gen 3 the picture above is a gen 3, it will fit in a GP shift pattern you have to play with it to get it right. And you also have to flip the shifter to Quick shifter so it's going in the correct push-pull patternAre ANY.... ANY OF YOU GUYS TALKING ABOUT A GEN 3?????????????? All I see and hear "it should work, my GSX1000 works, my GEN 2 works" There is no frickin room to 'flip' the knuckle on the Gen 3. Look at one...
oooooooorrrr correct me... I'm all ears and eyes.. Also IF you get it to 'flip'.. ON FRICKIN COURSE IT HAS TO PUSH PULL IN THE CORRECT AND PREVIOUS DIRECTION. How else will it work.?. wow...
