GSX-R/Busa Forks question???
Busa1166
Are the Forks the same from the Busa an the GSX-R 1K ??? If they are will it be a perfect fit fender bolts position??? Caliper??? an will the Busa wheel fit back on??? axle nut size an stuff.
And you may wondering why would you do something that stupid an what do you hope to gain from such a change.. Just trying to save a buck guy sold me the forks told me yeah there are Busa forks an then after I get them he tells me they came off a GSX-R 1K :down:
check with Gixerhp... I think he has the low down on all the Gixxer1K swaps
they are off an 02 GSX-R 1000 I am kinda sure that I am screwed, I just figure there is no way that I could get lucky enough for the fender bolts to line up.
This isn't going to work well for me... Thanks for the advice just ran the search on the subject. Not really worth all the hassle that's going to come with it. Thanks to the org. members for steering me in the right direction at least for my Busa needs.
They will work, but you need stiffer springs for sure! As well as few other pieces!
