OB_BarryW.
1. Do a search on cam chain failures. A month or so ago someone posted regarding Busa-powered race cars in the U.K. Evidently they were failing cam chains in that application due to rapid engine deceleration, but I don't know if was because of the factory chain tensioner or not. Jay from APE (manufactures aftermarket tensioners) was involved in some of the posts.
4.) I know MOTORHEAD has mentioned using overdrive 5th and 6th gears on his turbo engine, but I'm not sure who sells them.
5.) Need more info. regarding class rules that you'll be under. For example, if you can run a turbo you could probably get 250+ hp with good low end and midrange power (good in a car) and good reliability.
[This message has been edited by BarryW. (edited 09 July 2000).]
