you should have 170 psi min. for a decent runner. As high as 230 psi. The major thing to look at of course is the differences between the holes. 28 psi max diff.
If she's a high miler or in yer case,a high kilo motor,check a few things before slapping it back in yer frame. Stuff like the cam chain adjuster(make sure its gen 3) lift the cover off,check the clearances,all that stuff thats nasty to get too.
