Hey guys trying to see if yall can help me out again.
My bike isnt charging. It was holding 12.6 before now itll drop about .1v every 2 seconds or so even holding it at or above 4.5k.
Would the stator or rectifier need to be replaced? Or both.
Also i had to replace the harness a while back and the one i got the plug for the rectifier was cutoff so we butt connected the wires. Does the orientation of the yellow wires on the rectifier matter. It was 3 yellow wires that were the same so i connected those but didn't know if they had to go a certain way since all were the same color.
I did just check i see one is the signal line and 2 are charging lines but how do you know which are which on the harness.
