Hayabusa Swingarm Extension ????
Remove rear wheel, Its easier to leave the chain around the front sprocket then use it to pull the new chain through, Bolt on extensions, Just tighten them as tight as you can, set spacers where you want them for the length, ( I ran a broom handle through the wheel axle and slid it back and forth until I found the length I wanted ) put new chain on, put rear wheel back on. replace brake line and you should be pretty much done. As far as torque Im not sure there are specific settings
Ok I have a question about swingers vs extensions. I can get a 12" extensions for about $500 or swing arm for $1000. Are extensions this long still safe?
I dont understand? You will pay $400-$600 for swingarm extensions why not just pay a little more and get an extended swingarm from a reputable company? You can get a full underbraced extended swingarm from Evil Swinarms for less than a grand....:whistle:
