busarider2013
probem started the other night,,was at light bike got hot so i turned it off,,when i came back later to ride it home as i was going home at about 5k rpm was sputtering bad would not go past 5k rpm
so yesterday i took the compression all cyclinders 150-165 somewhere around there
..then i took the fuel pump out spray cab and choke cleaner in the fuel filter, and in the jets to clean all it of it out,,,put it back together and she ran like a champ down the road
,,,,,put her back in garage few hours later i went to take her out she would not go past 2k rpm sputtering and jerking bad
,,,so today i took out the spark plug replaced it,cleaned the fuel filter with carb and choke cleaner and put it all together and she cracks over after holding the starter for long time and dies does not even stay on for 3 sec.
.i keep doing it same results....put in dealer mode no codes...so i took the airbox out put some gas in there she stayed on for like 30 sec and died again and same thing will crank goes on cuts off.....will not stay on...what is the problem please help thank you....
