Head spacer
SxLxAxVxExN
I've tried searching but haven't really found any useful info.
While the turbo is being installed on the bike I might as well do a head spacer just in case. Better safe then sorry. So where can I get a decent spacer from and what size? I see that boostbysmith has the .080 but I don't know if thats too much?
Any info is greatly appreciated. Thanks guys
APE Sells .040 .063 .080 .100 .125
Schnitz add .032 to the above.
Several of our sponsors sell the above or can get a few others through Cometic as well by special order.
Okay so the .080 isnt too thick? I still wanna keep the bike streetable. I also found a website once where they were selling the spacer and head bolts as a kit and it was fairly cheap. Anyone know of that website?
080 spacer is real common, i can get one for you if you need it, though looks like others here can get you squared away
i can get whatever size you want that schnitz carries, they have most of those i think, but by far turbo guys usually go 080.
Also you will need
head gasket (go cometic)
adjustable cam sprocket(s)
head studs if you want while you are already in there
could do valve springs as well if you want
lower end gasket set
