Headlight Cover
Busa04
Can anyone guide me or help me? I am looking for a clear film,(not plastic cover)that i can put over my headlight glass to protect it from rocks and chips...thanks Joey
If it is a web site product,please include the link....
<!--EDIT|Busa04
Reason for Edit: None given...|1096702260 -->
Give this one a try. I haven't used it, but it may be just what you are looking for. <a href="http://www.performancemotorcycleparts.com/index.htm?content=http%3A//www.performancemotorcycleparts.com/lighting_pages/headlamp_covers.htm">Headlight Cover<a>
No that iasnt what I had in mind....I am looking for a film/not a cover...Thanks..Joey
<!--EDIT|Busa04
Reason for Edit: None given...|1096952555 -->
You can give 'Stonguard' a call. They make film covers for a lot of bikes. I don't see the Busa on their website, probably because of the challenging shape of our headlight. Anyway give them a try ... www.stongard.com
3M makes what you're looking for. It's a heavy gauge clear poly vinyl film that comes with an adhesive backing. You cut it to shape, remove the backing, then apply the film after first wetting the film and the surface you plan to mount it on with a water/rubbing alcohol solution (this lets you slide the film around until it's properly positioned). Use a body-work squeegee to work out any air bubbles, let it dry, and your set. Most body work supply shops carry it.
