04LE
Hi Org,
If i get an HID setup will i still be able to hook it up if my connector to the high beam looks like this? I bought the bike used and didnt check to see if the high beam worked and once i found out that it didnt i looked around and noticed the the plug is broke alittle. So i either need just the plug or if an HID kit will work ill just use that since i would like to upgrade the low beam anyway.
Thanks for the help!
Tom
Tom
