finaly found out what was the code when my f I light cames on the codes are 32,33,34,35 which are codes for the ignition system malfuction( the emc does not receive a proper signal from the fuel injector, faulty fuel injector, wiring or connector. Faulty power supply to the injector. "That is what my book said" any has pic of check fuel injectors and the wire or connector. I have replaced the battery ( brand new today fully charged) Do you have to take the tps out ( what type of screw is that, and how to remove it), do I have to check each injector connector / w ohmmeter, and remove each injector and check it. help I'am lost!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!lease:lease:lease:
