HELP!!!! 99 fuel return line tore
browning
hey getting ready to go on a trip checking the bike over the fuel return has a slight tear replaced it with some fuel line hose and used fuel injected clamps.it works but the return line is a molded line i'm worried it may crimp have had the tank down all seemed fine.will this work or am i gonna have to wait and get one from the dealership?
if you can take the spring off your old one and put it over the line till you find a replacement.
to keep line from kinking or collapsing the old line should have had one over it.
ok dealership had to order the part so i went and got some fuel injected hose redoing it now and putting the spring on hopefully this will work.anyone else have this kind of problem?
You didn't have to order it I bet you there are 10 floating around you could have gotten here cheaper.
