Help! Exhaust Studs….
///M+Busa
I’m changing out my cans with Yoshi RS3’s, are the studs supposed to come out of the OEM cans and installed in the yoshis? Cause they have no studs in them now?
Not sure on the Yoshi's, but when I had bolt-ons installed, I had to run to the hardware store and pickup some Stainless Steel bolts & washers.
FWIW...
Darn - I thought this was going to be a "how do I remove broken-off exhaust studs?" thread and I have the perfect solution to that!
Well anyhow, the next time you need to remove a broken-off exhaust stud, PB Catalyst and a blow-torch are all you need.
(///M+Busa @ May 18 2007,14:30) I’m changing out my cans with Yoshi RS3’s, are the studs supposed to come out of the OEM cans and installed in the yoshis?  Cause they have no studs in them now?
I used the factory bolts. Worked fine for me!
