help fixing fairing!
RussellJ
Rick Rollin'
I have an undertail that has a hole in it from the previous owners tire rubbing it. I am going to patch it and have it painted. What kind of material should I get to patch and smooth it up nice so it can be painted? Bondo is too heavy I've been told
Posted via Mobile Device
Depending on the size of the hole. Their are different materials out there to use,,,It depends on how big or jagged it is,,, sounds like a fiberglass compound would to the trick ,,unless its big,,then { If you able to reach inside,,,,,,} patch it their first witha patch and epoxy and smear a small coat of filler on the outside and sand it down after it cures,,,,,
From the pictures the guy sent it looks large. 2 or 3 inch diameter
A small webbing patch that they use on cars and to patch drywall holes is cheap and effective,,you can buy a small roll at walmart,autozone or home depo,lowes,,,,you have to have something like the webbing to smear mud[filler] on,,,,, the webbing{looks like a roll of screen,,] is tacking and very thin,, ,cut your patch,,put in over the hole,,or if you can get your hand inside,,but it really doesnt matter,,,,ive down walls and when I was done ,,,you couldnt see the patch,,,,then smear your mud,,let it cure,,,when apllying the compound use a small thin piece of flexable plastic,,,milk jug or cut out the side of a empty qt oil jug,,they work well,,,what ever you have,,use that to smear your compound filler,,,,let it harden [ cure] then sand it down ,,,if you get it close,,,make sure to use fine sandpaper,,,,
check out youtube...quiet a few HOW-TOs/tutorials there. here's one
I would patch it from the inside with some firberglass the use one of the many plastic weld compunds to fill it in from the front side then sand
