Mr Droo
Well, I can't get my helibars to clear the windscreen or upper dash panels at all. I literally spent 6 hours yesterday finagling with the bars, master cylinders, and top clamp...
The front end is lowered and I have an aftermarket top triple clamp (Probably a Yana Shiki) that I bought from Merisey a while back. I made sure I had the right side on the right side and vice versus. Can I assume the sides are indicated by the perspective of the rider? If my hands are on the bars whilst I'm on the bike, then my right hand is the right bar, instead of standing in front of the bike and assuming the opposite? It sounds ludicrous, but perspective is everything!
I was able to get the right side to clear, but I had to rotate the helibar really far forward, taking away any benefit they (are supposed to) provide. The right side switch housing was also rotated very far forward due to having the notch in the bar to hold the housing in position. The plugged in clicky thing (yes, that's the name I gave it!) underneath the lever was also compromised and I had to bend the two prongs on it to be able to put the connector back on. The throttle cables are spiegler braided lines and have no fitment issue.
I couldn't get the left side to clear at all. I re-routed the fast idle cable under the tank bolts, as indicated in the installation instructions provided. The clutch line becomes, IMO, too tight to keep that way long term without future issues. I tried to rotate it forward in an attempt to clear the outer part of the gauge cluster bezel (that's held in with push clips, near where the mirror bolts are), without joy.
I also removed the semi-rubberyish things the bolts go through, (to hold the top triple clamp and top triple tree together to the forks) in an attempt to lower the top triple clamp even more. It lowered it 1/8 of an inch, sans joy.
Being that the front is lowered and thus, the triple clamp is sitting lower than stock, I'm surprised I'm having ANY clearance issues. I have read about members having a genmar riser/soupy's risers whilst ACCOMPANYING a set of helibars without clearance issues. Other members have indicated that the total swap out time includes an allen wrench and a beer or two. I don't get it. I'm pretty frustrated at this point. I don't want to send them back or sell them either. I just want to have these dang things fit!
Sorry, no pics just yet. I was too tired and frustrated last night/morning at 2:30 a.m. to take any pics. If I have the gumption and motivation to give it another go today, I'll take some pics and post 'em up.
So, am I a noob or DSM IV: 318.2 ? (look it up if you have to)
PLEASE HELP ME! Please? lease:
Edit: Gen I 2005
Edit: Gen I 2005
