ej2006busa
Well I havent posted much to this forum because she has been running pretty well... except for a shaking that I cant get rid of!
I guess I'll start with the problem. The bike has 30k miles Ive had it for 20k. Below 100 the bike runs smooth with no problems. But as soon as you start to cruise over 100 she starts to shake, like an out of round tire or something similar. It's not as bad if your hard on the throttle, it gets worse as you start to cruise. It's not anything that feels dangerous, it just feels like its going to wear other things out, like suspension etc.
Now for what I've done to her...keep in mind this has been an ongoing problem mostly since I bought the bike. It has had a few times where she runs smooth, but very rarely. I've replaced the tires (both) several times. Replaced stem bearing, and had front forks serviced. New cush dampers, and chain, which I've adjusted several times towards high and low ranges of the spec. New rear rotor. I've checked the rims the best I can to make sure they're not bent or damaged. I went from dyna beads to weights, which the 1st time I did it seem to help but the weights slung off so I rebalanced them and it didnt help this time. My rear sprocket look pretty good both are stock but they dont seem to have any wear on them... at least the rear I cant see the front one. The new chain may have helped a little bit but she's still not like she should be. I'm sure Ive done some other things I just can't think of anything else at the moment. Anyways any help would be appreciated I can't take getting passed by cars on the highway anymore!!
