Ok so I bought an LM508 Alarm. It is installed and every option functions, so I decided to add the remote start option. I think to myself "Just hook up one wire" how hard could this be. After stabbing my finger with my test light multiple times and burning my finger with my soldering iron, I will have remote start. it says to find the ignition wire that has 12 volts when you turn the key on and 0 in all other positions ok sounds easy. to make a long story short-er I tried every wire coming from the ignition or "key switch" and still can't figure it out. I can get the engine to crank and all the lights come on but not the fuel pump can anyone tell me where to find the acc wire that will make all the lights and the fuel pump come on when you and 12 volts.
Go ahead I'm ready. "you should have bought a scorpio" "Blah Blah Blah" I can't afford a Scorpio Right now, but I need something to ward off would be thieves and for one third the price. "I can swing that".
Any help and Critisisim is apreciated
