Help me identify these wires
jphilipson
In the image below, I believe the white wire and the the yellow wire are the low and high beam respectively - with the red arrows pointing to them. Just want to confirm this as I need to tap these two wires for my LED controller, which controls the output levels.
Looking at the wiring diagram, I believe so. (Y, B/W, Br, B)
Wish I were home right now to verify.
Thanks.
I'm 99% sure I am right after tracing them. From the manual it looks like the white is low beam, the yellow is high, the brown is position lights, the light gray is turn signals and the Black/White is shared ground.
