OK here is the deal, 04 busa, sent to a shop, had turbo kit installed and tunes, bike ran 2 passes, turbo cooked and locked up for some reason,bike sat all year, i have an aeromotive tsunami fuel pump, rc injectors, aeromotive regulataor, velocity fuel rail, and " from what i was told" reprogrammed stock computer" ... i decided to put my bike back stock, so i pulled all the turbo stuff off....... left the fuel system and " reprogramed" computer on,,,, now i start my bike it idles, but when you give it gas it spits and sputters and throws long flames and sounds like its in the rev limiter at about 1500 rpms..... could it be my computer not reading correctly? or has anyone had this problem before??? too much fuel? i mean its bad completely not rideable,,,,,and the shop cut a rectangle out of my computers cover and did something inside if you are holding the computer there the plugs are facing down , the cut would be at the top right corner? has anyone seen this done before??? i just wanna ride my bike please help... if i do need a stock computer, can i keep my rc 60,lb injectors? any info would be helpful... thanks
