You should have a threaded bung welded in. The O2 sensor should sit a specific depth in the pipe to work properly. The bung will make sure its positioned properly. You can see the bung welded into my HMF highmount midpipe. Just putting a threaded hole in the midpipe will put the O2 sensor too far into the pipe.
