Brokenchickenleg
Last week after a ride of about 50 miles with no issues, I pulled to a stop in my driveway, shifted into neutral and noticed a rough idle for a few seconds before it died. The F1 light did come on during the rough idle. The bike started right back up but continued to run rough with the F1 light on. I killed the bike and decided look into it later. Yesterday, I cranked it up with no issue or sign of a problem. I let it run about 5 minutes then sat on it and backed it out of the garage. While backing out, it dies instantly. Not just the engine, all the electricity...guages and lights. I turn the key off and on again to hear the fuel pump as usual and everything seem to have powered up as it should. When I hit the starter button, all lights and guages flicker with the sound of the starter clicking as if there isn't enough battery power to turn it over. Then all goes dead again until I cycle the key off and back on. This happened two more times, then like magic, it started with no issue and ran fine for about 100 miles. During that ride, I stopped several times where I shut off the bike and restarted it. The only electrical mods are a PCV and a Speedo-Healer. Sorry about the length of the post, but I wanted to be fairly detailed here. Any ideas or similar problems??
