Hayabusa133
Hey guys, I have a 2006 Busa with PCV (Brocks strip Map), Brocks Alien Head Full exhaust, just installed Dyna 2000 with Dyna coills and APE Pro Manual Cam Chain Tensioner. After those last two installs I noticed that the bike is not idling when cold..
When the bike is cold it would not idle. If I set the Idle speed to 1150 RPM it will idle however when it heats up to normal operating temp the Idle speed goes up to about 1600 RPM...
Help me please guys.. could this be that my plugs are gone??? I changed them about 3 months ago and used them for about 3000 miles. They are NGK Iridiums...If not the plugs what else can it be???
I also advanced the ignition Timing with the Dyna 2000 can it be that its too much advanced???
Thanks
Mark Ramoutar
Thanks
Mark Ramoutar
