davidl9953
i was doing the pair mod, and happen to look into the throttle body, seen this...... what should i do to clean the valves off, without taking the motor apart !
I don't know much about Shell gasolines so I can't knock it, other than I didn't like the way it ran in my 450 hp sb Chevy in my Monte or the 425 hp sb I had in my Z-28. I personally run either BP 93 or Sunoco 94. I've got 9800K on my '06 and don't have any build-up.
WHAT????I would find a shop that has a true "Motor-vac"; which is a stand alone fuel cleaning system from Snap-on, Matco, or Mac, that has a cleaning agent mixed with it's own fuel supply and see how that works. We use one in our shop, but we are an automotive repair facility; tho, GENERALLY speaking, a combustion chamber is a combustion chamber. I do know the BG 44K kits do work well, but I think the Motor-Vac system is a bit more thorough. We actually have both systems in our shop and depending on the problem, could resort to the use of both. It is truly hard to actually remove all carbon deposits, but you GOTTA run a premium fuel to HELP avoid it. I don't know much about Shell gasolines so I can't knock it, other than I didn't like the way it ran in my 450 hp sb Chevy in my Monte or the 425 hp sb I had in my Z-28. I personally run either BP 93 or Sunoco 94. I've got 9800K on my '06 and don't have any build-up.
WHAT????
techron additive and in two tank of gas it is gone
Good advice.
Try the Shell in your bike, it works excellent in mine.
What is good enough for Ferrari is good enough for me!
techron $7.00
now how much is that cleaning?
what don't you understand
The following is a "Use at your own Risk" item... this is an old remedy I have used for 25+ years.. works like a charm and if done correctly, will not hurt a thing.. done incorrectly, you can shorten a connecting rod, blow head gaskets or generally trash a motor in short order.. if you feel you may have "hydraulic" on a cylinder (motor stalls and wont turn over) stop and pull the spark plugs... and spin motor over..
I have left parts of the below rather vague for a reason.. if you do not understand what is going on, then you probably should not use the system..
excessive carbon build up removal:
needle valve assy (to adjust the flow of solution)
rubber vacuum line
1 qt water
4 oz ATF
1/2 oz dawn dishsoap
mix and agitate
Slow slow feed into vacuum port on running motor until solution is almost completely spent.. increase flow until motor starts to miss.. kill engine..
let sit for at least 4 hours/ refire motor and hot lap the thing..
HUMMM , I like the old school of Marvel mystry oil.. My last truck was Run very very hard, it had 340k miles when I sold it used about a pint of oil B/T changes , I sold it to a friend a few years ago , and it still runs like scalded ape.. Mobil1 and Marvel oil & BPfuel. I guess it being a chevy ( 350 ) helps..
