help...power comander pink or black wire on install
GOLDBUSA
hooking up power comander v to my 08 busa...on the tb throttle position sensor it says to tap into the pink/black wire....well one wire is pink,and the other is black both solid... does this mean i can use either or color??...thanks...:banghead:
I found it .... I was in the wrong harness.... I was at the one on end of the tb this is just under it...thanks
