Help...roaring toyz swingarm tension bolt
highestgrade
Please share your advice on how to rectify this problem. i plan on replacing with stronger bolts...maybe just too much DAMN POWER!!! or is this a fault with roaring toyz swingarm???
I did the same thing when I 1st put mine on. thought I had the chain adjusted right and went around the block and dumped the clutch and the wheel moved forward a little and bent the bolts. so since I am right down the road I went in and talked to Bobby at Roaring toyz and he gave me 2 new bolts. and havent had that happen again.
WOW....... Thats Scarry ::9 Like mentioned above, I would definitely call and talk to Roaring Toyz about this. what method do you use to determine what your proper chain slack should be?
Those adjusting bolts shouldn't have any pressure on them, they're there for adjusting only. I would say that the axle nut was not tightened properly. I wouldn't ride it till the problem is corrected.
Stronger bolt required, but make sure you torque and pin that axle nut to the proper torque :beerchug:
