I gapped my plugs at 20...
It is probably your map... If you are running like #### before boost, your map is more then likely not tuned right for below boost... You should invest in getting her dyno tuned... It will be worth your money... When you do get it tuned, it may take some time to get it right and multiple times at the dyno... I remember one person on this forum claimed they had their bike on the dyno for 90+ runs before they got her running real smooth... Not saying that will happen to ya, but chances are good you need to adjust the map...
An idea... Use the buttons ont eh PC to kick up or down the low band of the PC. The buttons on teh PC will adjust the low, mid, high rpm areas and they get adjusted by a percentage when you use hte buttons instead of fine tuning with the computer... I will warn you, one bar makes a big difference... Decide wheather its running lean or rich and then tune it one bar at a time accordingly and see if that helps a bit...
Careful with your map, if you go lean, you are going to go boom under boost...
CLoud
