redrednose
I HAVE THE MSD89361 SHIFT LIGHT . IS THIS CORRECT I HAVE THE GREEN WIRE HOOKED TO THE YELLOW WITH BLUE STRIPE WIRE COMING FROM BEHIND TACH
ALSO DO I SET PROGRAM AT 2 OR 4CYL ....I CANT REMEMBER WICH ONE REQUIRES U TO SPLIT THE RPMS IN HALF OR WICH TO USE I NEED TO START TESTING BUT WANT SOME INPUT FIRST ?? BTW I HAVE AN 06 BUSA.
