No, I haven't needed to, but I would recommend using a breaker bar and or cheater before throwing an impact wrench on my tranny. If you do use an impact wrench , I recommend you have the bike in neutral.Did you use a breaker bar?
I would try it with a ratchet or pull handle before throwing an impact wrench on my tranny, but that's just me
I have never had an issue spinning this nut.
I always blocked the rear wheel and used a breaker bar until I read a post by a very well known engine builder who only used an impact. The trans. is always in neutral when doing this so I don't see what would be hurt.
Much easier with the impact plus no worry about pulling the bike over.
Mythos , with an impact wrench it won't matter if the rear tire is locked down or not.
Maybe if the bike is left in gear? In N, the sprocket will turn with the impact, NO?
