I need some clarification on CAT3's tutorial on the rebuild on forks. He says when refilling the forks with oil to mark the rod at 3.9" and insert into the fork and it should just touch the other rod when level with the top of the fork. But where is the oil level supposed to be at in relation to that 3.9" mark. Is it to be at the bottom of the rod that you insert into the fork?
