I've got a weak peg too
Do you have the Spring and check ball in place?
the only springs are on the fronts and I didn't see a check ball when I took them off. should there be?
YES, the rear ones have a spring with a ball at the end to catch on the holes in that plate. I have mine apart right now(going powdercoaters).......I will get you some Pics.
thanks I dont recall seeing those. I beter start looking around the garage floor.
