Mechanic916
I just bought a 2003 Hayabusa 3 weeks ago. Here is what happened first day getting it home there was a fuel leak from the charcoal canister. Fixed that a hose has come loose, after that it has progressively ran worse. it will start right up then stall within a few seconds, to get it started i have to open the throttle half way and let it run at 4500 rpm for 30 seconds, then it idles but is still running rich. fuel mileage is now at 15mpg.
About the bike it has 21500 miles, power commander 3, yoshimura slip on, and a tre.
what I've done i removed the tre, changed the plugs, replaced the air filter, and added techron injector cleaner. I tried to disconnect the pc3 but it will not run without it and the fi light flashes when cranking.
I have red posts back to 2012 on here and can not find the exact problem. what im thinking is the pc3 is over fueling.
Back ground on me is i'm an auto and diesel mechanic and have ridden bikes for 15 years my last one was a 05 sv6550s.
