OB_VegasDude
Going for an early long ride tomorrow. I need some info. while looking at the rear wheel on the side of the brake disc. Under the swing arm there is another arm approx 1/2 inch in size about 12 inches long and on one end connects to what appears to be the brake system and the other end connects to the underside of the swingarm. The bolt that connects this smaller arm to the brake mechanism had play back and forth in it. In other words i could move the bolt that holds this together back and forth with my fingers. Is this bolt supposed to be loose like that or tight...........please check your bikes and let me know. Thanks alot.
[This message has been edited by VegasDude (edited 13 August 1999).]
[This message has been edited by VegasDude (edited 14 August 1999).]
