High beam indicator lamp lights up
Tetge
I attempted a search before posting but I had no luck.  My high beam indicator light on the dashboard lights up momentarily when I am accelerating hard in second and third somewhere between 8-9000 RPM.  I noticed it today after I installed the PCIIIusb and went out to see if it felt stronger than before.  It did ride nice with the JohnnyCheese installed map but then I notice the indicator light coming on.
Any ideas what could be causing this?
<!--EDIT|Tetge
Reason for Edit: None given...|1123809456 -->
Bad bulb or connection to same.
When the circuit dosn't complete, it triggers a ground through the high beam indicator light on the dash... safety feature designed to tell daytime riders the light is not on.
Many bikes have this feature, even Kawasaki's.
