My high idle started to become less effective and then dissappeared all together. I have looked up adjusting the high idle in the service manual and all it has is a lousy picture and "adjust high idle screw (#) to 3500rpm. It doesn't say which direction and how to easily access the screw. The screw I have identified as the high idle screw is between the throttle cables and the airbox in a very hard to reach location. The screw head faces the front of the bike and has a spring on it. I took off the r/s fairing to make it easier, but I was still unable to turn the screw counterclockwise. I was able to turn the screw clockwise 1 full turn with no effect at all. I didn't think screwing it clockwise would work just by looking at the way it works, but since I'm unable to turn the screw counterclockwise I tried it just to see what would happen.
Is there an easier way to get at the screw? I think the reason I can't turn the screw counterclockwise is because I can't get the screwdriver on at a good angle. It doesn't make a sense because if you turned the screw counterclockwise enough the screw should screw all the way out.
Anybody adjusted their high idle before, advise?
<!--EDIT|Charlesbusa
Reason for Edit: None given...|1118901437 -->
