HMF Hight mount installs
ODFUBUSA
So I got my pipes in and just about all installed and man do they look great,
I did notice however the pipes on the bottom that come out of the X the first set of T bar clamps.. Seem to be leaking a bit. any tips on this I did tighten them up a bit more which help a bit the leak seemed to be less . So i tighten them a bit more and the T part snapped out.. Whats the trick to not have them leak.
I would like to knw too . I plan on getting them soon . Where did you get them and how much did you pay?
Yeah, make sure the mid pipe is all the way on (seated) if you'll notice, the area around the larger pipe is split to ease the installation, if its not all the way seated, it will leak through these splits in the pipe. Hope this helps, NJ.:)
Ill have to try that tonight to reset the mid section, I also have to go to the hardware store and try to find a clamp that is simular. Im thinking a regular O clamp should do the trick once i get them seated correctly
Did you break the clamp? If not it will do the job, just get the pipe all the way in.
Ya I broke it.... Im iching to get out of work right now to go reseat the mid section, LOL Cant wait to get out of here. SUcks having a new toy and cant use it yet
Thanks, that explains everything now.
alright I think i got it all set. I took the pipe off reseated it, and attched the clamp.. Seems to be ok now.. Now i have to find a new clamp.
