boostedgixxer
the charge pipe bumped into the radiator and put a pin hole in it. i can see where its pissin out and tried using some aluminum jb weld like i did before. before my upper bolt broke after having to suddenly abort out of a wheelie and slammed down. used a lil bit of jb weld on the spot and havnt had a problem in over a year with it. this new hole tho i cant seem to seal this way. anyway my question is i guess is it possible to put that radiator stop leak stuff in bikes? also my coolant is routed to my turbo as well, i can tell the hole is small because its just a tiny stream that pisses out after it gets hot. any suggestions for different fixes?
