Homemade mitey-vac
fstbusa
I installed some new brake lines and pads today. Couldn't get the front lines to even start taking fluid and I didn't have a mitey vac so I made my own.
worked really well.
all you need is
a rubber hose
glass of water for rinsing your mouth
and obviously your mouth.
must be cuz I grew up on the farm.
You could put a Tee in the middle with another line to drain off the fluid
Just put your finger over the drain line...suck out some air and fluid...then remove your
finger from the drain, let it drain into a cup or pan...then repeat the process as needed
With some clear tubing just keep a eye on the fluid and STOP sucking
before ya end up tasting it
