piratediverjefff
So i buy a Hotbodies black windscreen(and the dark smoke rear turn signal/taillight kit,yet to install...or try to installleaseand after a fight to the death finally get it on.The fit around the upper inside corners is crappy(see pic)so at the last minute decide to "tweak" it just ever so slightly and naturally the entire corner above the clutch lever snaps right off.Rather than pitching it or finishing it off by beating it to death with a BFH,i got out a Dremel with a cutoff wheel and after using the broken off piece as a template chopped off the other side(figure i had nothing to lose at this point,otherwise it was a $100 shot right in the ass).After about an hour of cutting,sanding,polishing,etc. i've decided it's pretty close so may run it for a while,i can always pitch it later if it bugs me too much.Just because of the poor fit i wouldn't buy another from Hotbodies(the black does really look good,even though in some of the pics it looks gray),maybe go with a dark smoke Puig,Double Bubble etc.
...snapped(broke!)the corner off!
...ready to cut off the other side
...somewhat of a matching pair
...cut off and sanded
...check out the really poor fit,and this is after the plugs,screws etc. are in place and totally buttoned up!
