You can either cut and past the link into your post or go to "preview" at the bottom of the post box.
Once in their you will see a small Icon of a globe with a couple of chain links through it. Click it and you can paste your link into it. Then click next and you can name it so it says click me instead of www.whateverthehell.com/tomanybackslashes/ihavenoclue.gov
Instead of using the quick post box, you have to reply to a post or start a thread. Above the reply box, there is a globe with a figure 8, when you click on that icon, a dialog box will pop up and ask for the URL - click OK then a description box will open and you type in your description. That simple.
or you could just type it in yourself like this...
[url]www.hayabusa.org [/url] ...without the spaces would just show the addy as a link~ Or...
[ url=www.hayabusa.org ] The org [ /url ] ...again without the spaces, and it will just show 'The org' as the link~ Such as the link in my sig below...
I just did it with the spaces to show the coding~ Tighten it all up and it will become the links~
<!--EDIT|GJoker
Reason for Edit: None given...|1145038151 -->
