How many bajo bolts on abs model?
Klutch556
Trying to order the banjo bolts for replacing the clutch and brake lines.
im at work and can’t go count mine on the bike and can’t find the info online.
someone help me out?
me luv u long time <3
Don't have ABS cant help there. Why do you need to replace the bolts? They never wear out(unless stripped or something). Replacement of the washers is never a bad idea thou. I'm on a learning mission here.
Rubb.
Rubb.
My new spiegler lines loop fittings are aluminum and the stock banjo bolts are stainless. When you mix steel and aluminum and they get wet it causes oxidation.
that and I’m a style slut and want my bolts to match my gold fittings:beerchug:
So ... 6?
1 ea at calipers = 3
1 ea at input levers = 2
1 ea at clutch slave??
I don't think the ABS unit itself has banjos
Ima go count now at the bike ...
[EDIT] maybe another one at the rear MC?
So ... 7??
So ... 6?
So ... 7??
round up to 8 just in case..........now for another question,is the banjo different for the clutch slave? :rolleyes:
2014 model. Same bolt for clutch master and slave according to the parts list
UNION BOLT (10x1.25x22mm)
