HOW MANY O-RINGS ARE THERE, WHERE THE OIL LINE MEETS THE OIL COOLER?(I
ever since i had the micron installed by a bike shop i've had a leak where the oil line meets the oil cooler on the left hand side. there's a spacer inbetween the oil line and oil cooler and between the spacer and the cooler there's two o-rings, is there suppose to be two there? i've taken this apart and retighten everything but it still fukking leaks!!
maniac
fukk there's only suppose to be one o-ring in there on that side(left) why the he!! would they have put two in there, would that be the problem of the leak? anyone else have one or two o-rings in that side?
maniac
There is a groove correct only on one side I believe this is where you are at.
What spacer?
[This message has been edited by Johnnycheese (edited 12 May 2000).]
O-rings are designed to work alone, never grouped together. The shop that put the pipe on your bike has a stupid novice mechanic or absent-minded tool spinner. Who knows, maybe they install customers oil filters with an extra O-ring, anybody who has a trace of mechanical skill would know better.
I did not need the spacer for the Micron full system after they sent me the correctly bent head pipes.
The spacer is bullSH#$. I have about 1/4" clearance between the cooler and the pipes now.
There may be two o-rings, I will have to look into the old instructions from last year on the Micron and post back.
JC--The spacer is to help with clearance if the head pipes come too close to the cooler and touch. They space out the cooler and then supply you with a spacer that goes between the oil line connection. I think one o-ring for each side of the spacer. They give you longer bolts also.
I DO NOT LIKE IT, because it places A LOT OF TENSION ON YOUR OIL LINE, WHICH COULD RESULT IN A LEAK! THAT WOULD BE A NICE THING TO HAPPEN IN A NICE SWEEPER.
Bob
Maniac Marshall,
I've got the same problem with the leak. Noticed a couple of drops on the garage floor last week. Got really uptight when the oil had blown a little underneath the fairing, and all the road grime had stuck to it; looked like I had a big problem brewing. I cleaned the underside with Honda Pro-Clean stuff, drove around awhile, and looked back under there, and could see it getting a tad wet around where the line goes into the cooler.
My dealer has to order the O-rings, and I was going to wait and see what all was going on before I posted here about it, but you beat me to it. I'll let you know what I find. Dealer's going to do it under warranty, of course.
