bubba_zenetti
can anyone tell me what sort of AN fitting i would need to build the oil return from the turbo to the oil pan?
also, has anyone ever attempt welding a bung to the oil pan and threading it for a 90 degree AN fitting? did it work out well? it would seem that welding a bung to a cast pan would be tricky yes?
all of the kit mods i have seen require you to drill the oil pan and use some sort of bulkhead fitting. i am a bit paranoid that something like that could come loose and dump oil everywhere.
thoughts or ideas?
thoughts or ideas?
