How to remove decals ?
NINJA KILLER
JUST CRUISN '
What's up , I was needing a little advice on how I can remove 2 Decals on tank without taking bike to a body shop ? Thanks for the help
use a hair dryer and get them warm and they will come fairly easy....use WD 40 to clean it up
Heat gun works the best . Make sure you know how to use it , don't over heat it.
What year bike? The 05+ have the little Silver "S" logo that peels right off. If it is older than that the "SUZUKI" is under the clear coat. I wouldn't know how to take that off myself. Are you ashamed that you ride a suzuki or something? Why take it off?
If your talking about the warning sticker then it just peels off and you can use goo gone to clean up the sticky mess. It helps if you use a hair dryer to heat it up a bit first. If your talking about the Suzuki or the color stripe stickers, those are under the clear coat.
I checked my 06 and if your talking about the Suzuki sticker, well mines under the clear coat ! I don't think I would try to peel that off
! But that's just me
