How to remove engine mount lock nut?
CVN
Is there a way to remove the engine mount lock nut with out having to buy the $67.00 suzuki special tool.
I found this pic of how it was done.
Pick the one you need and try and grind an old socket.
Hope it helps
Hope it helps
+1. This is what I did to take mine out. Works great. Just take the socket and mark where the slots are that you need it to go into and then cut out the places in between with a grinder. Takes a little time but well worth doing to save you almost $70
