Just removed this cover on leftside(where fuse's are located)so I can locate a plug in/or wire I can tie into for power supply to radar detector,among the logical fastners to remove there are 2 that are "Hidden",one is a large "pop
Pin" behind the Tach Bezel,and the other is a screw,slightly left of the large pop pin,both of these fastners are out of sight,and plastics that hide them have to be either removedor just slightly "Forced" out of the way so you can access these two...this should be "Pinned" with pics,I would but I can't seem to "post" picsdamn computer
P.S. what color wire can I use that is switched,that is under/near this fuse
panel for power supply?...and is the "08" wiring schematic similar to the older models???
